Backtick problem
Backtick problem
If I type `blah`abc and then backspace 3 times, I'm now forever stuck in ``.  "->" or left mouse click cannot get me out of ``.
Notion actually has a very similar problem, except that "->" does get me out of ``, but I have no visual indication (i.e., the I beam is still inside ``).
The only remedy I found is to start another block, and then backspace into this block.
Same problem with the beginning of ``.
