[Problem report] Numbered/Bullet lists loosing track
Hi,
I'm sharing here a use case that might be impacting others when it comes to using numbered and/or bullet lists.
Let's say we have Lista A, which is numbered, and List B, which is bullet. The List B, belongs to Item 2 of List A. In this situation, after including List B inside List A, it will break the number sequence of List A.
1. Item
2. Item
      · xxxxx
      · yyyyy
      · zzzzz
1. Item
2. Item
3. Item
The only use case that is respected is when the sublist is kept in numbered list as showed below.
