Spacing between blocks goes weird if blocks are changed from Header and back to normal paragraph
The amount of space between blocks (or rows if you want to call them that) is not consistent if items are moved around and there is or was a block with a different format in that place but was either moved or changed to/from regular "paragraph" to Header 1, 2, or 3. The result is a list of items that looks like there is an extra block in between some of the items but there is no block there, it's just a larger gap between rows because there used to be a Header or some other object that has different sized 'gaps' between other blocks that are above or below it. As an example I will upload with this post a list from A-E and you will see that between items B and C there is a large gap; there is no row or block in between them. The large gap is quite obvious and when these situations occur, which for me is pretty much daily, I find myself clicking there to delete the extra block, only to realize there is nothing between the rows, it's just leftover formatting from when there used to be a Header or some other format of object that was moved, deleted, or converted to a different format. I suggest Nimbus tech to create a note and test by making various formats of blocks, move them around, merge items, convert them etc to find out what causes the behaviour. I suspect likely it's simply leftover formatting from a header; so when a header is deleted / changed / merged Nimbus needs to also adjust the spacing programmed into that block.
