Web clips on some pages are showing strange text in the clip. The text occurs over the section where the tag and folder options are listed (see attachment).
I can save the article but can't specify the tags/folder. Note that the strange text doesn't show up in the clip within Nimbus Notes. Based on what I can tell from the text it appears to be an issue with the tag function.
This doesn't occur for all web sites, but it does occur fairly often.
