Web clipper issues
Web clipper issues
Hi, the Web Clipper doesn't seem to work on Chrome.  This is on a work computer so there may be some issues around my employer blocking certain things (the Notion extension does work however)
The errors I am getting include the following:
Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
Access to XMLHttpRequest at 'https://sync.everhelper.me/' from origin 'chrome-extension://kiokdhlcmjagacmcgoikapbjmmhfchbi' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I don't know what this means, but hope it helps support in finding out.
Thanks
